GregS_from_MI
Jan 01, 2022Apprentice
Found a neat way to connect my new devices to 2.4Ghz channel on the Orbi Mesh System
bout a month ago, I posted on the community site because I needed to add a camera to my network but my new Orbi AX4200 does not support a way to differentiate 2.4Gh from 5Ghz channels. Both networks ...
CrimpOn
Jan 01, 2022Guru - Experienced User
GregS_from_MI wrote:
What I learned is if you are displaying the SSID for the 2.4 channel, if you tap that SSID (in your network) you will get an option to Connect to that channel.
Congratulations on an excellent suggestion for Android users. I have a (dim) memory that WiFi Analyzer type apps are not supported on the iOS platform, so iPhone users may not be able to use this method.
I will do some tests to see how long the phone remains connected to the 2G WiFi channel. What a cool solution!
GregS_from_MI
You are absolutely correct, the app I used was on an Android phone so I don't know if this is available for iPhone.
- CrimpOnJan 01, 2022Guru - Experienced User
Well, grrr. Opened two WiFi Analyzer apps and could not find a way to get it to let me connect.
Mind sharing which WiFi Analyzer app worked for you?
- GregS_from_MIJan 02, 2022Apprentice
Here is what I'm using. As said before, this app is used on my Android phone so I am not sure if it is available for the iPhone.
I got the app from the Play Store. There are 2 versions of the app, standard and Premium, which I guess I purchased and don't recall. I've attached 3 files.
1. Screen shot of the app, selected About for this shot2. Screen shot of the download page on the Play Store
3. User guideI could only attach one file so it is number 2. sorry
Good Luck,
Greg
- McLongJan 02, 2022LuminaryGood look and I'm sure this will help others. I ran across a similar article online that discusses this method but just so others are aware I was unsuccessful switching to the 2.4ghz channel using a Samsung S21 Ultra on Android 12; However, I wasn't using the premium version so that may be the ticket. Glad you got your camera connected but still searching for a way to connect a hunter ceiling fan.
