droog
Feb 03, 2021Star
Frequent internet disconnects
RBR 850 internet disconnected Hi, I'm seeing frequent (at least 1x or 2x daily) internet outages these days. The log in the admin section of the router says "Internet disconnected". ...
droog
Feb 04, 2021Star
OK, thanks for posting.
I noticed in the log one time the disconnect was around the same time as an NTP time sync. Today my RBR850 device time was well out. I changed from "Netgear default" to cn.pool.ntp.org. It's not disconnected yet, but its only been a few hours. Seems to disconnect once or twice a day for me.
Cheers,
droog
eightninenine
Feb 04, 2021Aspirant
I have been using time.google.com for NTP for a long time, and my issues have only started occurring with greater frequency. When I get time later I will do a full reset. However, this doesn’t feel like a great solution, more like Netgear is grasping at straws. I am hoping that I can backup my settings and restore, otherwise this is a horrible task.
- droogFeb 04, 2021Star
Agree. That was just my last guess. I've wasted well over 80 hours trying to make this thing work. I'm getting threatening emails from school because my kids keep "cutting" remote learning classes, and my kids are screaming at me because the internet connection keeps going down.
Don't feel like debugging what feels like beta hardware and alpha software any longer. Sorry NG but your product is, well, ng.
Cheers,
droog
- FURRYe38Feb 04, 2021Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?You might try it. I'm in the USA region.
I'm using defualt NG NTP and have never see this issue:
Firmware Version: V3.2.17.12_1.4.14
CPU Load: 12.12%
Memory Usage(Used/Total): 491 MB/867 MB
System Uptime: 8 days 20:06:57
eightninenine wrote:
I have been using time.google.com for NTP for a long time, and my issues have only started occurring with greater frequency. When I get time later I will do a full reset. However, this doesn’t feel like a great solution, more like Netgear is grasping at straws. I am hoping that I can backup my settings and restore, otherwise this is a horrible task.- eightninenineFeb 04, 2021AspirantHi FURRYe38,
Thanks in advance, I have read these forums before and you are a great help to many people it seems.
I have loaded what I believe is the latest firmware: V3.2.17.12_1.4.14 (quite the identification!).
I use a DrayTek Vigor 130 as the modem. I even bought this specifically as I read it was highly stable and reliable.
I have used many of the wireless settings recommended by you in a number of posts, and other than that I use Google’s DNS servers and Google’s NTP server.- FURRYe38Feb 04, 2021Guru - Experienced User
I would try ISP DNS and default NTP. I don't use Google much on anything.
