JimTurkey
Jul 06, 2023Guide
From U-Verse to Vyve - What to do?
After being a U-Verse subscriber for many years, I moved to another house and changed my internet provider to Vyve. With that move, what changes from the Orbi end of things? Previously to run my Or...
- Jul 09, 2023
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Jul 06, 2023Guru - Experienced User
What Orbi model system do you have?
Try Orbi with the new ISP modem?
Does the new ISP modem also have a built in router? If so then leave Orbi in AP mode.
If not, then you could change Orbi back to router mode.
Has a power off for 1 minute then back ON with the ISP modem and router been performed?
Turn off and unplug modem.
Turn on computers and rest of network.
