JimTurkey
Jul 06, 2023Guide
From U-Verse to Vyve - What to do?
After being a U-Verse subscriber for many years, I moved to another house and changed my internet provider to Vyve. With that move, what changes from the Orbi end of things? Previously to run my Or...
- Jul 09, 2023
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Jul 06, 2023Guru - Experienced User
What Orbi model system do you have?
Try Orbi with the new ISP modem?
Does the new ISP modem also have a built in router? If so then leave Orbi in AP mode.
If not, then you could change Orbi back to router mode.
Has a power off for 1 minute then back ON with the ISP modem and router been performed?
Turn off and unplug modem.
Turn on computers and rest of network.
JimTurkey
Jul 06, 2023Guide
I have the AX4200 WiFi Mesh System (RBK753) with 2 satellites.
One Eero router was installed to the modem. Assuming Orbi is a better product (and since I already have the router + 2 satellites), I am going to replace the Eero.
- JimTurkeyJul 06, 2023Guide… oh and the modem:
Hitron
Model: CODA-45- JimTurkeyJul 06, 2023GuideHow and at what point do I change from an AP to Router?
- FURRYe38Jul 07, 2023Guru - Experienced User
Most CODA models are gateway modems, thus built in routers:
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode- JimTurkeyJul 07, 2023GuideGotcha. Been through that process before with AT&T!
So when the installer set up the eero, he must’ve set it up as an AP? It was working great … just not reaching all ends of the house.
