JimTurkey
Jul 06, 2023Guide
From U-Verse to Vyve - What to do?
After being a U-Verse subscriber for many years, I moved to another house and changed my internet provider to Vyve. With that move, what changes from the Orbi end of things? Previously to run my Or...
- Jul 09, 2023
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
JimTurkey
Jul 09, 2023Guide
Moving the satellite helped. I might even toy with eliminating it. Thanks for your help!!
Jul 09, 2023Guru - Experienced User
Enjoy. 📡
