andrewsolo
Jan 21, 2025Aspirant
Frustrated, MOEN Water Shut Off Valve Disconnecting From Orbi RBR750
Hi, My MOEN Smart Water Valve always connects to the RBR750 and then disconnects after 1 hour. I am told by support for the Orbi mesh system make sure to have band steering turned off to have a mo...
Jan 21, 2025Guru - Experienced User
What FW do you have loaded on the RBR? V7 FW provides a separate IoT network for IoT devices.
- andrewsoloJan 21, 2025Aspirant
Thank you for trying to help. I think you are asking firmware? In phone app it says v4.6.9.11
- FURRYe38Jan 21, 2025Guru - Experienced User
Ok ya, v4 doesn't have separate IoT network support.
Do you have any RBS? if so, are they RBS750 or 350s?
- CrimpOnJan 21, 2025Guru - Experienced User
This device clearly contains only a 2.4G radio:
Since the device connects for one hour, the Orbi Attached Devices display (or Orbi 'app') will will indicate which WiFi band it is using. (Bet it's 2.4G)
Thus Band Steering cannot be the issue.
