andrewsolo
Jan 21, 2025Aspirant
Frustrated, MOEN Water Shut Off Valve Disconnecting From Orbi RBR750
Hi, My MOEN Smart Water Valve always connects to the RBR750 and then disconnects after 1 hour. I am told by support for the Orbi mesh system make sure to have band steering turned off to have a mo...
Jan 21, 2025Guru - Experienced User
Ok ya, v4 doesn't have separate IoT network support.
Do you have any RBS? if so, are they RBS750 or 350s?
CrimpOn
This device clearly contains only a 2.4G radio:
Since the device connects for one hour, the Orbi Attached Devices display (or Orbi 'app') will will indicate which WiFi band it is using. (Bet it's 2.4G)
Thus Band Steering cannot be the issue.
