getjams
Aug 13, 2020Aspirant
Frustrating experience with devices staying on the weaker Orbi unit
Unfortunately I cannot select my product model because they haven't added it yet to the list of products but this is for the new RBR750 AX4200 mesh system. Firmware 3.2.15.25_1.3.15. I bought thi...
Aug 13, 2020Guru - Experienced User
Ok if the distance is about 40 feet, you shouldn't need to move it farther away from the RBR. If anything you could try a bit closer to the RBR. Say 5 feet closer.
I would not recommend setting 500 for CTS. Keep 64 however you can try 2347. I don't know if 2347 will make any different though. I've been told by NG to keep with 64 for CTS value for Orbi AX.
So when the laptop connects to the RBS, does it maintain the connection while it's nearest the RBS?
getjams
So far yes, it does maintain connection to the satellite while upstairs once I am connected to it. I am out in my back yard right now and it's back on the RBR which is about 15 feet away.
The CTS/RTS stuff is still a little foreign to me. The reason I changed it is because I have a Nest theromostat and read about some potential issues there and also an extensive Sonos system and I was experiencing a couple odd Sonos issues so that was a troubleshooting step for that.
- FURRYe38Aug 13, 2020Guru - Experienced User
Yes NG is aware of NEST issues. So far with mine, CTS 64 and 20/40Mhz with AX enabled, my NEST controllers are working well. I did have a couple of disconnects the other day, however has been online since. I'm on v32. Something I recommend you try.
NG said there is a ping ponging effect happening when NESTs are connecting. Distance from the RBR or RBS is a factor. The closer the NEST is to either RBR or RBS seems important. My 3rd gen is 5 feet away from the RBR while my 1st gen is over 10 feet way from the RBS nearest it.
Regarding the Laptop, it's up to most any wifi device to pick and choose which signal source to connect to. So with the laptop it may connect and prefer the RBR vs RBS. Distance from each will be a factor and possible the laptop wifi may not support any Roam features so onces it's locked on to a singnal it may not move to a closer singal until you disable the wifi radio on the LT then turn it back ON. Nature of the beast here.
- getjamsAug 13, 2020Aspirant
Can you elaborate on the v32 firmware? I am not quite sure what that is. My FW is up to date according to the app.
