Wizzard370's avatar
Oct 03, 2022
FTTP ISP requirements with Orbi
Currently Orbi connected to Virgin Media (in Modem mode). All Ip addresses provided by Orbi.
Planning to switch to an FTTP ISP and I can connect my Orbi mesh (RBR350) straight into the ONT port.
The ISP has suggested I use Authentication type as PPPoE. Only place I can see a reference to this is under IPV 6 header where I can choose
PPPoE as an option from a drop down menu.
Is there any other place to change to PPPoE or is it only in IPV 6? Currently IPV6 option is disabled.
  • PPPoE is the option on the Internet page of the setup menu, "My ISP requires a password"
    Once you select that, then other options show up
1 Reply
  • CrimpOn's avatar
    CrimpOn
