jmdll0518
May 19, 2020Aspirant
Fustration Galore
Three months ago I purchased the AX6000 Orbi WIFI 6 Sytem. I have had nothing but issues. I have lost connnection or laptops not finding the WIFI. I have at least 6 tickets open and closed. Recen...
- May 26, 2020
All seems good. There are lags in connections but no drops. I am happy. Marking this solved.
May 19, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
Is the RBS wireless or wire connected?
What is the Mfr and model# of the ethernet switch in the configuration?
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
- jmdll0518May 19, 2020Aspirant
I have Spectrum High Speed Internet.
Modem is ARRIS Surfboard SB8200 for Spectrum
Orbi says it is in Router Mode
RBR850 is wired to Arris. the RBS850 is wireless connection to RBR
Home is under 1800 SF single level I would say the satelittle is about 40 ft from router.
Forgot Firmware.
V3.2.11.2_1.2.13 - FURRYe38May 19, 2020Guru - Experienced User
Turn OFF the RBS and use the RBR alone. Can your devices wirelessly connect to the RBR and maintain the connection?Do you get any indications on the RBR or RBS with the front LED?
Be sure that CTS and RTS values are changed to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
What is the mfr and model# of the laptop and the wifi adapter installed in the laptop?- jmdll0518May 19, 2020Aspirant
Thank you for helping FURRYe38. It is much appreciated. ]
I tried the connection without Satelittle and it did hold conenction but very weak the only lights I see when connection is lost is a blinking White Light that indicates to me it is trying to find the router, by the way both router and satelittle blink white when it has connection lost. I have restarted the Modem and Orbi multiple times. The onyl reboot I do for the Orbi was the tiny reset button. I changed the CTS and RTS values from 64 to 2347. The Laptop I am using is a dell latitude E7440. The wifi is the interanl dell one I updated 3 months ago when I got the AX6000
