kmurph
Feb 07, 2022Aspirant
Galaxy S9 connects to router but no internet
We have set up the Orbi router and 1 satelite using the same name and pw as the ISP. Devices have connected and are working as they should except one. We have 2 Samsung Galaxy S9 phones. One connect...
CrimpOn
Feb 07, 2022Guru - Experienced User
Is the ISP WiFi still active?
kmurph
yes
- CrimpOnFeb 07, 2022Guru - Experienced User
If they both have the same SSID/password, how do you know which WiFi system devices are connecting to?
- kmurphFeb 07, 2022Aspirant
They show as connected devices in the Orbi App.
Do you have a device with a larger screen (laptop, tablet, desktop) that can be used to access the Orbi web interface? (http://orbilogin.net)
If you bring up the Attached Devices web page, does it show (at the top) that Access Control is "on" or "off"?
