skremer62
Jan 15, 2023Aspirant
Garage Enclosure and Ring
I recently bought the Orbi 960 (RBKE963B) series. To increase coverage outside I will be hard-wiring a back-haul to the garage. However, the garage is not currently heated/cooled so over the past c...
CrimpOn
Jan 15, 2023Guru - Experienced User
Attached Garage or separate building?
skremer62
The garage is attached.
- CrimpOnJan 15, 2023Guru - Experienced User
The low temperature doesn't worry me much at all. And, there are simple solutions for that (because the satellite has to have electrical power).
- Put the satellite in a cardboard or plastic box.
- Put a regular heating pad under it, with
- A means to turn the heating pad on when the temperature drops under 32 degrees
- Such as a Smart Plug.
It's the 132 temperature that is more of a concern. Ordinarily, I would say, "aim a fan at it." If the outside temperature is not as hot, a simple duct with a fan to pull outside air in and blow it over the satellite would probably do the job. (I have a similar issue that my garage gets too hot to work out in during the summer, and I'm considering adding an exhaust fan up high to pull hot air out and let cooler air in.) I've had an RBS40V in the garage for two summers and it did OK. If it gets fried, I'm only out $99 (they were on sale at Amazon years ago.) An RBSE960 is a TON more money.
(I had originally thought about a small insulated duct from the house, through the garage to the satellite, and back to the house with a small in-duct fan (search Amazon for "inline booster fan for hvac") The biggest issue there is the house/garage walls are almost certainly fire-rated and running duct work through them is a building code issue.
