tak1313
Mar 23, 2021Luminary
Ghost in the Orbi!
OK, so many here will say Netgear can't afford the best software engineers. To wit, I present to you a ghost in the Orbi app of things past and long dead. I have an RBK752, which as most know, i...
- Mar 23, 2021
Firmware Is the latest - don't remember off hand.
It was no big deal - did not require a reset. Just went back into the web gui again and it was now there as a disconnected sat. Deleted it and it's no longer in the gui or the app.
Now if it shows up again I'm going to be really annoyed.
Mar 23, 2021Guru - Experienced User
Try a factory reset on the RBR and RBS and setup from scratch with a wired PC and web browser. After the systems is setup again, then check the Orbi app...
