tak1313
Mar 23, 2021Luminary
Ghost in the Orbi!
OK, so many here will say Netgear can't afford the best software engineers. To wit, I present to you a ghost in the Orbi app of things past and long dead. I have an RBK752, which as most know, i...
- Mar 23, 2021
Firmware Is the latest - don't remember off hand.
It was no big deal - did not require a reset. Just went back into the web gui again and it was now there as a disconnected sat. Deleted it and it's no longer in the gui or the app.
Now if it shows up again I'm going to be really annoyed.
Mar 23, 2021Guru - Experienced User
What FW version is currently loaded?
tak1313
- FURRYe38Mar 23, 2021Guru - Experienced User
Possible this is a Orbi app issue. Seen odd things when it comes to this app. :smileyfrustrated:
