tak1313's avatar
tak1313
Luminary
Mar 23, 2021
Ghost in the Orbi!
OK, so many here will say Netgear can't afford the best software engineers.  To wit, I present to you a ghost in the Orbi app of things past and long dead.   I have an RBK752, which as most know, i...
  • tak1313's avatar
    tak1313
    Mar 23, 2021
    Firmware Is the latest - don't remember off hand.
    It was no big deal - did not require a reset.  Just went back into the web gui again and it was now there as a disconnected sat.  Deleted it and it's no longer in the gui or the app.
    Now if it shows up again I'm going to be really annoyed.
