dejan2604
Jan 24, 2021Aspirant
Ghost Satellite on the network Map
Hi, I have a very strange problem. I have Netgear Orbi RBD850 and one connected satellite RBS850 (over WiFi). Software version is: 3.2.16.22. Everything is working just fine except that on the netwo...
- Jun 18, 2021
Hello Orbi Community!
Thanks as always for the amazing engagement in this NETGEAR community. We are aware of the bug where an Orbi satellite that isn’t in your system occasionally shows in the Network Map in the Orbi app. This is a display issue in the app and not a security issue and there is no functional impact of this bug. We are working on a fix for it which we expect to roll out soon.
Thank you for your patience.
Christian
Jan 24, 2021Guru - Experienced User
Try a full factory reset on the RBS and RBR and setup from scratch using a wired PC or laptop using a web broswer.
Ensure FW on the RBS is the same as what's loaded on the RBR...
