Dd852
Apr 06, 2022Luminary
"good" vs "poor" backhaul status
Does anybody have any insight into how the web UI diffferentiates between "good" and "poor" backhaul status? My light shines blue on sync; the speed off the satellitre seems fine (c. 300 up down - an...
Apr 06, 2022Guru - Experienced User
What orbi do you have? (model)
You put their daisy chaining?
It could be the satellite switching from a daisy chain connection to directly connecting to the router.
- Dd852Apr 06, 2022Luminary
850 with two satellites. The second satellite has no possibility of connection with the router: I pick up only signal traces from the hidden channel with a sniffer. It connects to satellite one which itself has a good 5gHz connection to the router.
Satellitre two glows blue on setup and much of the time appears as "good" but sometimes appears only as "poor". Yet devices connected to it seem fine.
