jdurand
Nov 04, 2021Initiate
Google home issues with RBK850 network
Since upgrading to the RBK850 wifi 6 mesh network devices I have had all kinds of issues with my Google Home devices. My biggest issue is with speaker groups: I have 11 speakers in a group and when ...
Mikey94025
Nov 04, 2021Hero
It may be a routing issue between the satellites vs. which wifi band. Does this solution work for you? https://community.netgear.com/t5/Nighthawk-Mesh-System/Chromecast-and-Mesh-Routing-issues/td-p/1946485
The solution (for me and my AX1800, I hope it works for you)
1. Go to your routers home page (typically 192.168.1.1)
2. Select Advanced Settings
3.Select Setup tab
4. Select LAN Setup
5. Scroll down to the "RIP Direction" section
6. Ensure "Both" is selected for "RIP Direction"
7. Select RIP_1 for "RIP Version"
