daledx00
May 17, 2022Aspirant
greyed out DNS in web app
Hi. I have the below Orbi 6 and suddenly the "Use These DNS Servers" option under "Domain Name Server Address" option is greyed out, even though I have been using public DNS servers through this inte...
- May 18, 2022
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
May 17, 2022Guru - Experienced User
What happens if you disable Armor?
I believe if Armor is active, it uses it's own DNS services.
