daledx00
May 17, 2022Aspirant
greyed out DNS in web app
Hi. I have the below Orbi 6 and suddenly the "Use These DNS Servers" option under "Domain Name Server Address" option is greyed out, even though I have been using public DNS servers through this inte...
- May 18, 2022
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
May 17, 2022Guru - Experienced User
What happens if you disable Armor?
I believe if Armor is active, it uses it's own DNS services.
daledx00
Disabling Armor has no effect. Even when Armor is active (as it has been for years) I could always use custom DNS servers before. Now whatever has changed is forcing the use of Comcast's DNS servers (I looked up the IP address and it is Comcast). Couldit be that Comcast is forcing NG to disallow non-Comcast DNS servers? I tried resetting the Orbi but no change.
