daledx00
May 17, 2022Aspirant
greyed out DNS in web app
Hi. I have the below Orbi 6 and suddenly the "Use These DNS Servers" option under "Domain Name Server Address" option is greyed out, even though I have been using public DNS servers through this inte...
- May 18, 2022
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
daledx00
Disabling Armor has no effect. Even when Armor is active (as it has been for years) I could always use custom DNS servers before. Now whatever has changed is forcing the use of Comcast's DNS servers (I looked up the IP address and it is Comcast). Couldit be that Comcast is forcing NG to disallow non-Comcast DNS servers? I tried resetting the Orbi but no change.
May 17, 2022Guru - Experienced User
If you disconnect the RBR from the modem, then press the reset button for 15-20 seconds then release and wire connect one wired PC to the RBR and setup the RBR from scratch, is the DNS section still grayed out?
What browser are you using?
- daledx00May 17, 2022Aspirant
Yes, I tried resetting but no change. I am using Chrome beta 64. I get the same greyed out using other browsers.
- FURRYe38May 17, 2022Guru - Experienced User
Did you do this while the RBR was disconnected from the modem though?
IF this was the case and you reset the RBR, the DNS options should not be greyed out...and if you select the radio button Use These DNS address selection...
Yes, I did the reset without being connected to the modem. I understand that it should be showing the radio button as selectable but it is not.
