rickerr63
Dec 08, 2021Aspirant
Guest Access to Attached Devices
I have a guest network because I have some devices that cant support WPA3. Any way I can set up to use WPA3 on the main network and WPA2 on the Guest network so that Guest can access wired network d...
Dec 08, 2021Guru - Experienced User
What model Orbi do you have?
I believe Orbi AC series does not have WPA3 support at all.
Orbi 3/7/8 series systems have WPA3 support however don't offer mixed WPA2/3 support. We hope in the future NG will support this as the new Orbi 9 series does support mixed WPA2/3 support.
- rickerr63Dec 08, 2021Aspirant
Thanks. I have the RBR750 Mesh Router with 2 satellites (it's not in the dropdown list on this forum for some reason). All work perfectly with WPA3 enabled and I have WPA2 on the guest network to allow some devices that dont support WPA3 to connect. I wanted to give the guests access to my printer for example which is hard wired to the main router. I also want them to be able to see NAS drives on the loca network.
I could go back to WPA2 on the main network so that all can connect but wanted to use WPA3 if I can for increased security.
There was some discussion about options to allow guest to see each other and access LAN devices but I cant see those options in my Guest Network setup.
Cheers,
