zapp7
Feb 26, 2021Star
Guest network broadcasts, devices can connect, but no internet
Like the title says, the guest network is enabled and broadcasting. Devices can connect to it successfully, however there is no internet access on the guest network. My main WiFi network is functioni...
- Mar 20, 2021
Annnnd now it's working. Go figure!
zapp7
Mar 19, 2021Star
The firmware is V3.2.16.22_1.4.9.
It's connected to an Actiontec T3200M (configured to just pass through the signal to the Orbi), which is connected to a Nokia Intertek ONT.
How could that affect the guest WiFi on the Orbi?
zapp7
Mar 20, 2021Star
- FURRYe38Mar 20, 2021Guru - Experienced User
Interesting. Not sure why you were having problems first off. No idea. You can choose to keep whats loaded as FW or update as well, as v 12 is available for manual download.
- SrivabhinavMar 25, 2021Guide
I have the same issue with RBR850. What was the fix for this issue? The solution link doesn't seem to be working.
- zapp7Mar 25, 2021Star
There wasn't actually a fix, I just noticed it was working one day.
I read somewhere else that people have had issues with the satellite not broadcasting the guest network. That may be what my issue was, but I'm not sure. I haven't fully investigated yet. I don't use the guest network very often, so I haven't gotten around to looking into it.
