zapp7
Feb 27, 2021Star
Guest network broadcasts, devices can connect, but no internet
Like the title says, the guest network is enabled and broadcasting. Devices can connect to it successfully, however there is no internet access on the guest network. My main WiFi network is functioni...
- Mar 20, 2021
Annnnd now it's working. Go figure!
Srivabhinav
Mar 25, 2021Guide
Sorry I should have mentioned that as well. Already done - no luck :(
Mar 25, 2021Guru - Experienced User
So after a factory reset and setup from scratch, later on, enabling Guest Network, nothing is getting connected while on GN? What happens if you disable WPA security temporarily on GN and connect something, anything get thru?
- SrivabhinavMar 25, 2021GuideThe devices connect just fine but they lose internet connection every few mins (for like 2 mins). After 2 mins( approx )they start working again. WiFi stays connected the whole time just internet stops on GN only.
- zapp7Mar 25, 2021Star
I wonder if this could be weak signal due to the satellite not broadcasting the guest network? Maybe try connecting to the guest network on your phone when you're right next to the main router, where the signal is strong, and see if the internet still drops out.
Have an Apple TV couple of feet away and have the same issue on it as well if I connect Apple TV to the GN.
- FURRYe38Mar 25, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. 40-50 feet max distance. - SrivabhinavMar 25, 2021Guide
Approx 2000 Sq ft. I assume that is not the issue since the main network works flawlessly.
Yeah, that's why this issue is kind of mind-boggling. Don't know how the main WiFi could work while the guest network just doesn't.
The guest network on my previous Google WiFi had no issues. It's pretty obviously an issue with the Orbi.
