zapp7
Feb 27, 2021Star
Guest network broadcasts, devices can connect, but no internet
Like the title says, the guest network is enabled and broadcasting. Devices can connect to it successfully, however there is no internet access on the guest network. My main WiFi network is functioni...
- Mar 20, 2021
Annnnd now it's working. Go figure!
Mar 25, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. 40-50 feet max distance.
Srivabhinav
Mar 25, 2021Guide
Approx 2000 Sq ft. I assume that is not the issue since the main network works flawlessly.
- zapp7Mar 25, 2021Star
Yeah, that's why this issue is kind of mind-boggling. Don't know how the main WiFi could work while the guest network just doesn't.
The guest network on my previous Google WiFi had no issues. It's pretty obviously an issue with the Orbi.
