iwoodchuck's avatar
iwoodchuck
Follower
Apr 12, 2023
Guest Network DNS
What DNS server does guest network use when enabled?  I have my normal one using certain ones that control traffic to certain sites, but the guest network seems to allow when turned on and does not s...
  • FURRYe38's avatar
    Apr 12, 2023
    Typically Guest Network devices get DNS from the router so it would be the routers IP address used for DNS.
    Guest Network DNS is not user configurable.
