DCP4971
Apr 23, 2023Luminary
Guest Network IP range
Hi all, So, my core network IP range is 192.168.1.1 - .244. Guest network used to apply 192.168.2.1 onwards, but I've noticed that it's now applying a 10.0.1.. range to devices connecting to the ...
Apr 24, 2023Guru - Experienced User
What model Orbi do you have?
Ya GN should be at 192.168.2.x. Odd that it changed. You sure it changed?
DCP4971
Apr 24, 2023Luminary
Minor details missed out..soz
RBK853, running V4.6.14.3_2.3.12
Connected to Sagemcom F3896LG-VMB
Is defo reporting a different IP range for GN - can test at will connecting my phone to the GN.
I have a horrible feeling I'm going to have to factory reset..
- FURRYe38Apr 24, 2023Guru - Experienced User
What mode is your modem working in?
That's a modem gateway with built in router and wifi already. Since the GN is tied to the WAN port, seems that the modem is in router mode and causing the GN to change it's IP address range. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- DCP4971Apr 24, 2023Luminary
Hmm, thanks. The Sagemcom is in router mode, with Orbi in the DMZ (I have one IoT device connected to the wifi on it).
I'll have to have a play around tomorrow when the place if free of people that will complain if t'internet is up and down like a yo-yo - will change back to modem mode for the Sagemcom and see if this encourages it back to the normal range.
Did wonder what would happen if I temporarily changed the Lan setting on the Orbi to disable then re-enable 'Use router as DHCP server' to see if this reset the assigned ranges.
K, that is probably the reason.
If 10.s is working then you could keep it.If you go back to modem mode, which would be preferred, Try powering off the RBR then back ON and see if the GN range changes back to 192, if not, a factory reset maybe needed.
