mbarylski
May 16, 2021Guide
Guest Network is slow
I'm having problems with the guest network. The connection is fine, and speeds show that everything is working, but apps aren't connecting. It's really slow or buffers forever. There don't seem to be...
mbarylski
May 17, 2021Guide
I have the RBR850 with the latest firmware connected to Verizon Fios. It seems to work off and on. Not sure why. If I disconnect and reconnect the WiFi guest network it works, but it doesn't persist. After awhile it stops working and I have to drop the connection and reconnect again.
mbarylski
May 17, 2021Guide
What do you mean update my signature line? With what? Model of my orbi?
The modem is the Verizon Fios ONT. It's all built in to their outside box, and the CAT6 just runs to the Orbi. So all I have is the Orbi, and WiFi is coming from the Orbi.
Btw, I noticed that switching WiFi on and off doesn't always work either. I have to switch off the private connection and switch it back on.
