mbarylski
May 16, 2021Guide
Guest Network is slow
I'm having problems with the guest network. The connection is fine, and speeds show that everything is working, but apps aren't connecting. It's really slow or buffers forever. There don't seem to be...
bdsmith63
Jul 04, 2021Apprentice
As an update to this thread, I contacted Netgear support this morning and opened a case regarding the issues with the guest network running on firmware 3.2.18.1 on my RBR753/RBS753 system.
After going through all the troubleshooting steps, we reverted back to firmware 3.2.17.12 for the router and satellites. I have been testing devices for over 3 hours now with no hiccups. Support said to report back in 24-48 hours and they will escalate my case regarding the issue with the latest firmware.
mbarylski
Jul 05, 2021Guide
Wow, that's interesting. If the old firmware works, I hope they're able to identify the issue quickly and fix in the next update.
Just in case this isn't a quick fix, how'd you drop back to the old firmware?
- bdsmith63Jul 05, 2021Apprentice
Just in case this isn't a quick fix, how'd you drop back to the old firmware?Just to the Netgear downloads page: https://www.netgear.com/support/download/
After I downloaded the previous version of the firmware for the router and satellites, you just go into the manual upload section of your firmware update on your Orbin login. I used a laptop that was wirelessly connected near the router. I did the router first, then the satellites.
So far I've tested loading the guest network and haven't had any issues.
- mbarylskiJul 05, 2021GuideAwesome, thanks!
