mbarylski
May 16, 2021Guide
Guest Network is slow
I'm having problems with the guest network. The connection is fine, and speeds show that everything is working, but apps aren't connecting. It's really slow or buffers forever. There don't seem to be...
mbarylski
Jul 06, 2021Guide
Yes, thank you! Really appreciate all the updates and helping push this forward. Really hope they apply a fix to all the routers that are having this issue. Are they aware that it's multiple Orbi's that are affected? I'm using the "RBR850 — Orbi WiFi 6 Router AX6000 / RBR850". I'd imagine they all use very similar firmware, but there may also be slight differences as well.
Jul 06, 2021Guru
Have only seen a couple of users post about this. We don't get detailed information like what all users have seen this from support. I presume may see this or some may not depeneding upon if they use GN. I don't here.
All is same FW per each model Orbi. So could be a problem for all or only some specific effected users. Something NG will have to review.
