mbarylski
May 16, 2021Guide
Guest Network is slow
I'm having problems with the guest network. The connection is fine, and speeds show that everything is working, but apps aren't connecting. It's really slow or buffers forever. There don't seem to be...
bdsmith63
Jul 06, 2021Apprentice
mbarylski wrote:Yes, thank you! Really appreciate all the updates and helping push this forward. Really hope they apply a fix to all the routers that are having this issue. Are they aware that it's multiple Orbi's that are affected? I'm using the "RBR850 — Orbi WiFi 6 Router AX6000 / RBR850". I'd imagine they all use very similar firmware, but there may also be slight differences as well.
I did report to NG that my previous system (RBR50/RBS50) had the same issues after I updated it to the latest firmware about 2 months or so ago. I told them that other users have reported similar issues with their Orbi systems as well, so it's likely a problem with the latest firmware on all them, but again like FURRYe38 said it may or may not be affecting certain systems....
