mbarylski
May 16, 2021Guide
Guest Network is slow
I'm having problems with the guest network. The connection is fine, and speeds show that everything is working, but apps aren't connecting. It's really slow or buffers forever. There don't seem to be...
mbarylski
Jul 08, 2021Guide
Blanca_O wrote:Hi mbarylski
If you are willing to work with support on the issue please let me know and I will PM you requesting for more information.
Blanca
Community Team
Hi, yes, definitely! Happy to provide any information you need and test a different firmware version.
bdsmith63
Jul 08, 2021Apprentice
Thanks Blanca! Glad to help!
- bdsmith63Jul 08, 2021Apprentice
FURRYe38 wrote:I would definately ask about the beta thats availale and test on your systems. Mines loaded with it currently.
I will certainly do that, I believe Blanca asked if I'd be willing to do some testing with firmware, I assume it'd be the beta and hopefully no hiccups with it....have you been able to use Traffic Meter with it? I find it interesting to glance at now and then, but not necessary on a daily basis.
- FURRYe38Jul 08, 2021Guru
Yes, TM is enabled...and ya, don't look at it on a daily but seems to be working...
- bdsmith63Jul 13, 2021Apprentice
Update: Netgear contacted me today by telephone. We've setup a support call on Saturday (7/17). They will gather the necessary information on the previous firmware version that I downgraded to and is stable, and then also have me capture data on the latest firmware that seems to have the issues with the guest network. So I'm glad they're going to work with me to troubleshoot and hopefully get this corrected on all firmware versions with these issues. I will be making them fully aware of this since I had the same issues on my previous system.
- FURRYe38Jul 13, 2021Guru
Ok keep us posted.
Not seeing anything while using beta FW that was offered.
Hope they can help you figure this one out.
- bdsmith63Jul 30, 2021Apprentice
Hello! As an update with Netgear Support, I had a call from the support technician I have been working with for several days. She called me this past Sunday (07/25) to let me know that everything I had submitted and uploaded from the testing was being escalated to their team of engineers.
She said I may or may not hear anything back right away, but they would be working through the logs and files that were sent through my testing. So hopefully we'll see some updates soon!
- FURRYe38Jul 30, 2021Guru
Thank you for the update. Good to hear they know about it. Hopefully will get it fixed in next FW update.
- bdsmith63Sep 09, 2021Apprentice
Just an update, haven't heard a thing from Netgear since they worked with me in July with support files, etc. I inquired on my case and have not had a response. My trial support period ends in a few weeks and I would like to get a response from them? We've not had a FW update with any resolution?
- FURRYe38Sep 10, 2021Guru
Make contact with NG support.
- mbarylskiSep 10, 2021Guide
Thanks for the update. It would be really nice to hear from them AND get a firmware update. If your case is still open they SHOULD keep it open until the firmware is released. I hope you're able to get a hold of them to confirm that they can keep it open until the firmware with fix is released.
- bdsmith63Sep 10, 2021Apprentice
You're welcome! I will keep in touch and continue to follow with NG support. Any updates, I'll gladly share!
- kal7Nov 18, 2021Aspirant
I have a similar issue as well on my orbi AX6000. Model: RBR850. I tried to rollback as suggested. I don't see "yes" after uploading the file in manual firmware update.
Any updates on the issue are appreciated. Thanks!
