mbarylski
May 16, 2021Guide
Guest Network is slow
I'm having problems with the guest network. The connection is fine, and speeds show that everything is working, but apps aren't connecting. It's really slow or buffers forever. There don't seem to be...
AF007
Nov 20, 2021Aspirant
I have the same issues with my RBR850 + 2 x RBS850. I have had this issue for a long time with different versions of Netgear firmware. I don't see how this can be related in any forms to the modem or internet provider when I get flawless connection on the regular SSID but a lot of dropped packets on the Guest SSID which makes it very slow to the point of being useless. I have tried different devices, at different distances and disconnected all other devices expect for the test one and always had the same result; Guest SSID intermittently stops working, and when it works it’s very slow.
It's very disappointing to see how a very expensive mesh network setup like this can't handle basic tasks like a Guest SSID properly even after a bunch of firmware updates :(
I don't recommend Netgear mesh networking to anyone anymore! Cheaper alternatives provide similar and in some cases better experience.
- bdsmith63Nov 20, 2021Apprentice
Good Morning Folks! After an extensive amount of time helping Netgear support with testing my guest network, the beta version they sent me seemed to run without any issues -- the latest firmware release I thought fixed the guest network issues. My son was over a week ago, was using his iPhone on my guest network, he was still experiencing intermittent issues browsing various websites that I didn't have any trouble with on my regular SSID. I ended up buying 1 year of support with Netgear. It was in July and over the past few months that I worked with support. At this stage I am very frustrated with Netgear -- such an expensive setup and they can't seem to fix a simple issue that wasn't broken before?
- FURRYe38Nov 20, 2021Guru - Experienced User
What version of FW worked for Guest Network for you?
- bdsmith63Nov 21, 2021Apprentice
FURRYe38 wrote:What version of FW worked for Guest Network for you?
The last firmware version that I recall working fine for the guest network was 3.2.18.1 or 3.2.17.12.
I thought the beta that support sent me was working well, and it was whenever I tested any website, except it always seemed when my son would be over and use it, he'd encounter an issue with a particular website not functioning properly, I tried to replicate it on my device and couldn't.
I guess at this juncture, I'm just going to have to turn off the guest network and just let guests use my regular network as it's been very frustrating trying to get this issue resolved since July with support.
