stodium's avatar
stodium
Follower
Feb 14, 2022
Guest Network Issues (Slow & Disconnect)
Firmware Version: V4.6.3.16_2.0.51
Model: RBR860 - Orbi Wifi 6 AX6000
Issue:
I'm currently facing two issues...
1.) My guest wifi network is super slow. While I do get great speeds on my main network, the speeds on my guest network have been atrocious. Almost unusable.
2.) Since connecting guests, I notice my router drops signal a lot. Causing me to unplug my modem and router and then replug them back in to reboot the connection (have had to do this the past 5 days in a row now). Is their any reasaon this might be happening? Called my ISP and they told me everything looks great on their end with the modem and that it seems to be a router issue.
Are their any steps I can take to mediate these two issues, especially issue #1 (guest wifi speeds)
Side note my ISP plan is for 1000 MBS speed.
