bychin's avatar
bychin
Follower
Feb 15, 2021
Guest network on Orbi mesh node
Am I able to set up a guest network on an Orbi WiFi 6 AX6000 (RBK852) mesh node? My current mesh system only allows a guest network on the router and not the node. I would like to set up the guest network on the node since it will be in a room closer to where guests would stay.
  • When Guest Network is enabled, it's enabled on all Orbi RBR and RBS units.
1 Reply
  • FURRYe38's avatar
