BlueSurf
Jul 15, 2020Aspirant
Guest Network use............
I have the Orbi WiFi 6 System (RBK753S) AX4200 Mesh System. I set up the Guest Network and I gave it a name and very long password. I checked off Security Options (WPA3-Personal [SAE]). On my...
- Jul 15, 2020
The guest network is designed to be separate from the main network resources -- with the exception of reaching the WAN.
Your guest network will NOT/should NOT be able to see main network resources (like printers, cameras, alarms, NAS's doorbells, etc).
That is the purpose of a guest network, to give internet access (WAN) but to protect internal resources you dont want guests snooping in.
The encryption on the network has nothing to do with what can be seen in the guest network... it is merely the encryption techniques used on that wireless network.
Jul 15, 2020Guru - Experienced User
Be aware that WPA3 maybe not be backwards compatible with wifi devices. WPA3 is still new and being developed. The WPA community and wifi router mfrs are still working on getting WPA2 and WPA3 working together. I believe there are problems thus NG hasn't made an option for mixed mode WPA2 and WPA3 to be enabled at the same time. So if you have any wifi devices that do not support WPA3, you'll need to select WPA2 and AES to ensure your wifi devices work with the Orbi system.
BlueSurf wrote:I have the Orbi WiFi 6 System (RBK753S) AX4200 Mesh System.
On my main set up I checked WPA2-PSK [AES].
If I use the guest network on my iPhone 11 Pro Max will I be able to acess everything on my main network? Home automation, Alaarm system, etc.
Can someone explane if in my Main network this should be checked/used? WPA-PSK [TKIP] + WPA2-PSK [AES]
Checking this, will it lock us out of anything?
I remember checking this on my main setwork and not being able to access the internet?
I wish NetGear would give much more information on these security features.
Thanks for your comment.
