PsyB
Nov 02, 2022Follower
Guest Network won't disable
I have exactly the same issue. Guest wifi turned off in the app and the website. Reboot, reset... Guest network always come back. I changed the name. same thing.
Orbi RBK752 with firmware V4.6.11.1_2.3.6
1 Reply
Try what this user did?
"Seem to have disabled it (for now) by changing the name, turning it on and then turning it off again."
Or:
