wasima's avatar
wasima
Guest Network
Hello - Just purchaed and installed an Orbi (AX) with two satelites RBR850 and RBS850 - updated frimaware V3.2.9.2
Main network works great - so happy to get full inbound internet via wfi now everywhere. However the Guest network which I renamed, works for a few minutes and then stops.
The Time period setting is set to Always.
Have tried rebooting devices, router and satelites, doesn't seem to make any difference.
Any suggestions welcome.
Thanks
  • wasima's avatar
    wasima
    Feb 09, 2020
    Took your advice and looked at the settings on the combo modem//router couldn't find anything so decided to change out the ISP provided device for a new docsis 3.1 Spectrum E31U2V1 - which is just a modem (and no Web UI).
    i got a speed bump ;) But no change
    did factory reset on the router followed by resets on the satellites - no change.
    Noticed that the Orbi Router handles the Guest network correctly and stably.
    RESOLVED by unplugging satellites from Ethernet and using wirelessly.
    either there's an issue with Ethernet backhaul or more likely I have something going on with the multiple switches that I have in some of the rooms.
    Thank you FURRYe38 For your help
  • FURRYe38's avatar
    hat is the Mfr and model# of the ISP modem the NG router is connected too?
    • wasima's avatar
      wasima
      Hi - the satelites are wired
      The ISP is Spectrum, Modem is Ubee DVW32CB
      There are neighbours in the building I'm in -- but not seeing any issues with the primary wifi network, only the Guest network.
      Haven't done a factory reset/setup after the firmware update - happy to try that next.
      Thanks
      Wasim
