Jeffgear
Oct 07, 2024Virtuoso
guest WLAN isolation
Hi all Although I use my Guest WLAN for visitors to access the internet, as intended by his feature, I'd like to also use this WLAN for a development Raspberry Pi project I'm working on without c...
- Oct 07, 2024
Guest Networks are isolated from the main WLAN for security reasons. Used to have the ability long ago to give access but NG took that away for security reasons.
I don't believe you can set a IP address reservation on the main side since the GN is a seperate network and the lease times are short for the intended design of short transient connections while on the GN.
Oct 07, 2024Guru - Experienced User
