askld
Oct 25, 2024Aspirant
Guidance on Home Network Setup with Orbi (RBR850 and 3x RBK850)
Hi, I’m looking for help from you experts! I recently bought a Netgear Orbi router (RBR850) along with 3 satellites (RBS850) because the Zyxel VMG router provided by my ISP doesn't deliver su...
askld
Oct 26, 2024Aspirant
Is this switch (D-Link DGS-1024D) compatible with my system?
Oct 26, 2024Guru - Experienced User
I think that is a managed switch. Make sure the any IGMP and Green Ethernet protocols are disabled on that switch if seen if you are going to try and ethernet connect the RBS to the RBR using the switch.
