Must_Function
Jun 19, 2022Aspirant
Had to replace CAX80 router modem connected to RBK 850 to CM2000 modem.
Originally had the CAX80 connected to ORBI 850RBK. CAX80 was in router mode with wifi disabled and RBR850 was in AP Mode. Had great coverage and speed with no issues for several months. I have numer...
Must_Function
Jun 20, 2022Aspirant
Thank you for the advice. All my cameras are hard wired via netgear switch, which is connected to the Orbi router. I have a feeling that my remote helper has one of the ethernet wires incorrectly plugged in. I will be at the location in a couple of weeks, so for now, the cameras that I had the MAC addresses on, I went in Orbi setup & reserved fixed ip's in the 10.0.0._ numbers, and viola, they are connected wirelessly for now. Once I am at the location, I will figure it all out. I have 38 devices connected presently and they are all working fine. I decided that having some cameras up is better than none. I will post an update, once I find the issue. I think it stinks that after paying $500 for the CAX80, that I really liked, Netgear released bad firmware making it useless and not caring how it affects their customers. They need to put more effort in technical support and admit when it is their fault.
Jun 20, 2022Guru - Experienced User
MIght check with a forum moderator, there is a beta being made available for the CAX80 with 5Ghz issues.
