RD3AV5
May 06, 2020Aspirant
Half the desired speed of RBK852 AX6000 mesh system
I just purchased the AX6000 after a lot of research to use with my gigabit Internet. While wired I get 800-900 mbps average, WiFi is about 400 mbps on an iPhone 11 with WiFi 6, that is only about a f...
- May 07, 2020
The wifisweetspots test is a connection rate between the device at the iphone. Not a thruput speed test. Ooklas speed test doe the thruput test.
May 06, 2020Guru - Experienced User
Most wifi devices unless fully supporting of AX Modes and connection rates above 1300Mpbs, will max out at around 400-500Mpbs wirelessly. Wired devices should always see near 900Mpbs.
I see the iPHone 11 s AX supporting however only 2x2 MIMO
802.11ax Wi‑Fi 6 with 2x2 MIMO
https://www.apple.com/iphone-11/specs/
The Orbi AX is 12 stream MIMO wifi.
So the phone maybe limited on seeing actual 900mbps thruput speeds.
One thing you need to do is download wifispeetspots on your iphone then run this app while the iphone is connected near the RBR, say 3-6 feet line of site. See what connection rate the iphone is connecting at to the RBR. Should be 1300mbps - 2400Mbps at least.
RD3AV5
You would think with the 5 GHz on the Orbi supporting 2400 mbps and the phone supporting 1300 mbps theoreticals it would hit 700 mbps or so just fine. I have read reviews and seen how an iPhone 11 can at least hit that (https://www.youtube.com/watch?v=unc36O66Ef0) and was expecting something similar. There are only a couple of other SSID's near me and didn't think it would affect it much, but still, getting 350/400 or so vs 700/800 mbps I was expecting still disappointing, even when accounting for at least a 25-30% reduction expectation from theoretical speeds it should still hit it.
