RD3AV5
May 06, 2020Aspirant
Half the desired speed of RBK852 AX6000 mesh system
I just purchased the AX6000 after a lot of research to use with my gigabit Internet. While wired I get 800-900 mbps average, WiFi is about 400 mbps on an iPhone 11 with WiFi 6, that is only about a f...
- May 07, 2020
The wifisweetspots test is a connection rate between the device at the iphone. Not a thruput speed test. Ooklas speed test doe the thruput test.
RD3AV5
You would think with the 5 GHz on the Orbi supporting 2400 mbps and the phone supporting 1300 mbps theoreticals it would hit 700 mbps or so just fine. I have read reviews and seen how an iPhone 11 can at least hit that (https://www.youtube.com/watch?v=unc36O66Ef0) and was expecting something similar. There are only a couple of other SSID's near me and didn't think it would affect it much, but still, getting 350/400 or so vs 700/800 mbps I was expecting still disappointing, even when accounting for at least a 25-30% reduction expectation from theoretical speeds it should still hit it.
May 06, 2020Guru - Experienced User
Need to find out what connection rate the iphone is connected with the RBR.
- RD3AV5May 06, 2020Aspirant
It is about a foot away from the RBR and is at 5 GHz at channel 44.
EDIT: I just downloaded WiFi Sweetspots and will test and report back.
- FURRYe38May 06, 2020Guru - Experienced User
And what is the connect rate the phone is connecting at using wifisweetspots?
Interesting! I was hitting an average of 760 mbps on the WiFi Sweetspot app. These are more the speeds I was expecting. I do wonder why Ookla Speedtest is telling me much slower than that.
