ARugg
Jul 28, 2020Tutor
hard wire PS4 recs
I am using a cable modem, CM1100, and the Orbi AX4200 system. Cable at 500Mbps. I have no issues running three apple TVs, three Ipads, a MacBook, and three phones, I am satisfied with their performan...
- Jul 28, 2020
You can ethernet connect the PS console to the RBR for best performances. If you have run out of free LAN ports in back, you can install a external Gb switch, such as NG GS108 to help add LAN ports to the back of the RBR.
Jul 28, 2020Guru - Experienced User
