GaACETech
Jul 21, 2022Guide
Hardware vendor wants 2.4Ghz only; no negotiation between 5 and 2.4
Orbi 6 router with 2 satellites. A client has Sonos speakers install throughout his house. Their technical support wants the router to not auto-negotiate between 2.4 and 5Ghz. And they call thi...
CrimpOn
Jul 21, 2022Guru - Experienced User
GaACETech wrote:
Or is it easier just to turn off the 5Ghz and just have the 2.4?
Good Grief, no. It is impossible to "turn off" the 5G WiFi signal on Orbi routers. Plus, that would reduce the capability of the entire system.
Sonos speaker systems (not a single speaker here or there) are a complicated topic. My Sonos One is perfectly happy, although I get annoyed when it will not respond to "Alexa... Stop".
Perhaps if you describe the issue, people who have experience with Sonos can help.
