myosin
Feb 10, 2023Guide
Hardwired satellites not connecting to Router
I've had lots of problems with my Orbi. I have spent so much time with Level 2 on the phone trying to get my Orbi stable. I ended up hardwiring all my satellites because the wifi backhaul was so poor...
- Feb 10, 2023
Are the satellites running through a switch?
What firmware is on the satellites? usually you want to upgrade the satellites firmware first and then the router.
Do they show up through the browser gui and not the app? I've had issues with the app not displaying satellites before.
myosin
Feb 10, 2023Guide
Two of the satellites are through a switch.
Through web browser I logged into system and was able to update the satellites. I set the system to auto update firmware.
The satellites are back online.
"Maybe" it was the app not showing the satellites. I had SO much trouble with the this netgear set up that I periodically check the app to see if everything is online. I guess I should check via the web browser interface.
Feb 10, 2023Guru - Experienced User
I'd trust the web interface more.
What switch are they running through?
I've occasionally seen issues with people using smart/managed switches.
Also, how far apart are the router/satellites?
Sometimes it helps to actually decrease their broadcast power if they're causing interference or poor roaming with each other.
- myosinFeb 10, 2023Guide
Through a netgear switch. It is not a smart/managed switch.
Routers are spread out. Two on first floor, two on second floor.
Seems to be working. I will go to the web interface to verify satellites are working when I see a problem on the Orbi app.
- plemansFeb 10, 2023Guru - Experienced User
4500 sq ft using the RBKE960 kit with 3 satellites. You might have a little over coverage. the router +2 satellites is rated for 9000sq ft.
Might be worth trying to play with your broadcast power and see what you get for stability.
I have 3 satellites total. The two that came with the kit and then an additional purchase.
