dcsaul
Oct 14, 2021Aspirant
Harmony Hub Not Attaching to New Orbi RBR853
Hi. Just bought an Orbi AX6000 RBR853+2 satellites, to replace my Linksys Velop. Everything has connected to the new network, EXCEPT my Harmony Hub. The hub connected to the Velop fine, but it will...
- Oct 15, 2021
SOLUTION: I did a factory reset on the hub and remote. The process went smoothly!
Oct 15, 2021Guru - Experienced User
Try disabling AX mode on the RBR under Basic Tab/Wireless settings and set CTS to 2347 Under Advanced Tab/Advanced Settings/Wireless Settings
dcsaul wrote:
Hi. Just bought an Orbi AX6000 RBR853+2 satellites, to replace my Linksys Velop. Everything has connected to the new network, EXCEPT my Harmony Hub. The hub connected to the Velop fine, but it will not connect/pair with the Orbi.
I have tried:
1. turning it off/on
2. pressing the reset button and trying all 3 reset options
3. changing to a more powerful power cord
4. the manual connection option using bluetooth
5. etc.... everything ever posted on the web for this problem.
I cannot see it on my network, so it does no good to try the scan all IP addresses.
On my Orbi I just have the one primary network setup: no guest, IoT, etc.
Does ANYONE have an actual answer for this? Thanks very much!
dcsaul
Oct 15, 2021Aspirant
Firmware Version
V4.6.3.16_2.0.51
