alchemista
Mar 27, 2025Tutor
Has anybody solved the boot loop problem? Orbi RBS750 and others
There are many posts across the Internet about the Orbi devices getting into a boot loop, where it stays on for just about a minute and reboots. None of the typical methods work - 30-30-30, 1minute r...
Mar 28, 2025Guru - Experienced User
Haven't seen many posts about this boot loop. Maybe one or two here.
If the 30-30-30 reset doesn't recover units, then most likely the unit has just gone bad and needs replacing.
Nothing else we can do about that.
