alchemista
Mar 27, 2025Tutor
Has anybody solved the boot loop problem? Orbi RBS750 and others
There are many posts across the Internet about the Orbi devices getting into a boot loop, where it stays on for just about a minute and reboots. None of the typical methods work - 30-30-30, 1minute r...
alvine
Mar 29, 2025Tutor
Hi,
I posted before(Orbi RBS850 stuck on boot loop) and it seems to be a hardware issue even though I managed to reflash the firmware. You need to use a static ip address set the lan to 1gb speed and use wireshark to monitor.
Make sure you only have LAN and Router connection without wifi.
There will be a small window time for the nmrpflash.exe to connect to the router/satellite. You may need to do this many times while checking the wireshark (you will see the mac address of the netgear responding)
alchemista
Mar 29, 2025Tutor
Did yours work after you flashed it? Or are you saying that even though you flashed it, it would not work?
It wouldn't be hardware issue if it started working after flash - that would probably be a corrupted firmware.
- alvineMar 31, 2025Tutor
Hi,
Since the firmware was re-flashed 2 times(latest) and the unit still stuck on boot loop. I haven't tried re-flashing to its original firmware quite some time now.
- alchemistaMar 31, 2025Tutor
Well I guess then this boot loop is irrecoverable which stinks.
