alchemista
Mar 27, 2025Tutor
Has anybody solved the boot loop problem? Orbi RBS750 and others
There are many posts across the Internet about the Orbi devices getting into a boot loop, where it stays on for just about a minute and reboots. None of the typical methods work - 30-30-30, 1minute r...
alchemista
Mar 29, 2025Tutor
Did yours work after you flashed it? Or are you saying that even though you flashed it, it would not work?
It wouldn't be hardware issue if it started working after flash - that would probably be a corrupted firmware.
alvine
Mar 31, 2025Tutor
Hi,
Since the firmware was re-flashed 2 times(latest) and the unit still stuck on boot loop. I haven't tried re-flashing to its original firmware quite some time now.
- alchemistaMar 31, 2025Tutor
Well I guess then this boot loop is irrecoverable which stinks.
